I just need to access a list of a few strings, that must be stored somewhere in order to query them.
What would be the simplest way to do that? To create a 1-table DB? To write a file? And then, how to access it? Which datasource to use?
I’m using Grafana v11.0.1 on macOS Sequoia.
I cannot store them as a constant or a custom variable, because I then need to access them from a panel depending on the selected value of a custom variable.
i.e.
I have defined a custom variable X whose value is: a,b,c,d
Depending on the selected value of variable X, I need to access a list of strings(s1,s2,s3); afterwards, I’m going to repeat panels while iterating over that list.
So, whenever I select X=a, I expect a datasource to retrieve those string values (s1,s2,s3) and do something with them.
