We are expecting 200 - 400 MBs of Log per day.
What is the hardware requirement for Loki? Processor, Storage, and RAM
There is no specific requirement per workload currently documented (may be coming next year), but due to the different metrics to be taken into consideration (volume, change rate, parsing overhead, network latency …) it is hard to recommend for specific use case.
If you are deploying in containers you can scale up easily depending on the workload, if you are doing traditional (local), the best answer is to start small and measure performance as workload increase and scale up.
Hope it helped somehow.
Good Luck
