export let options = {
stages: [
{ duration: ‘20s’, target: 10 },
//{ duration: ‘50s’, target: 600 },
输出结果:
ws_sessions9个,如下:
running (48.6s), 00/10 VUs, 9 complete and 0 interrupted iterations
default ✓ [======================================] 00/10 VUs 20s
✓ Connected successfully
checks................: 100.00% ✓ 9 ✗ 0
data_received.........: 254 kB 5.2 kB/s
data_sent.............: 157 kB 3.2 kB/s
iteration_duration....: avg=30.77s min=30.72s med=30.74s max=30.94s p(90)=30.85s p(95)=30.9s
iterations............: 9 0.185118/s
vus...................: 1 min=1 max=9
vus_max...............: 10 min=10 max=10
ws_connecting.........: avg=636.92ms min=608.95ms med=643.28ms max=669.49ms p(90)=650.62ms p(95)=660.05ms
ws_msgs_received......: 692 14.233527/s
ws_msgs_sent..........: 285 5.862074/s
ws_session_duration...: avg=30.66s min=30.62s med=30.66s max=30.69s p(90)=30.68s p(95)=30.68s
ws_sessions...........: 9 0.185118/s
ws_sessions13个,如下
running (32.2s), 00/10 VUs, 13 complete and 0 interrupted iterations
checks................: 100.00% ✓ 13 ✗ 0
data_received.........: 97 kB 3.0 kB/s
data_sent.............: 80 kB 2.5 kB/s
iteration_duration....: avg=12.17s min=10.9s med=12.34s max=12.77s p(90)=12.76s p(95)=12.76s
iterations............: 13 0.403712/s
vus...................: 1 min=1 max=10
ws_connecting.........: avg=632.99ms min=614.27ms med=628.95ms max=682.33ms p(90)=640.94ms p(95)=657.58ms
ws_msgs_received......: 229 7.111542/s
ws_msgs_sent..........: 150 4.658215/s
ws_session_duration...: avg=11.34s min=10.71s med=11.25s max=12.56s p(90)=12.03s p(95)=12.29s
ws_sessions...........: 13 0.403712/s
先2分钟内连接上1000个vus,然后10分钟内压测老师和学生互相收发消息,用下面的场景,对吗?
stages: [
{ duration: ‘2m’, target: 1000 },
{ duration: ‘10m’, target: 1000 },
Hi @bingbing, Welcome to the community forum
Unfortunately I don’t think anyone on the team knows chinese
. Can you please ask your question in English if possible
, thank you.
Websocket, set progressive scenario vu10, the output result ws_sessions number is not 10.What are ws_session_duration and WS_sessions? What does it have to do with the following scene setup
stages: [
[1000 VUs are connected in 2 minutes, and then in 10 minutes the teacher and the student send and receive messages to each other, using the following scenario, right?
stages: [
I still understand your question is.
stages
is a shortcut for ramping-vus
and
stages: [
means over 20 seconds go from the initial vus
number(by default 1
) to 10
so in this case around every 2s
it will start 1 more vu.
Each VU on it’s own will execute the default
function and when it’s done, it will start again and so on.
So in this case you are having 10 VUs that manage to finish 13 iterations - likely because they seem to take around 11s+.
With
stages: [
you will start 1000 VUs over 2m and then keep them for another 10m . How many iterations will be done is dependand on what the default
function does.
I understand. Thank you.
Is there a way to connect all VUs first (Enter the studio) and then execute the default functions for all VUs
The execution of the default
function is where the connect to the websocket server happens, if that is what you meant.
If you want to just start with a number of vus (and still use `stages) you can do something like
stages: [
{ duration: ‘0’, target: 1000 },
This will start 1000 VUs at the beginning and then keep them running for 10m
If you want to start sending messages only after all 1000 VUs are connected - you will need to implement this somehow … through the web server :shrug:. VUs in general don’t have any way of communicating in between themselves that aren’t through outside sources, such as a websocket server
