Websocket: close 1006 (abnormal closure): unexpected EOF on navigation
Brief summary
When the testing script runs for over 30 seconds the browser closes automatically, disrupting the test.
xk6-browser version
k6 v0.42.0 ((devel), go1.19.4, linux/amd64)
OS
Ubuntu Linux 22.04.1 LTS
Chrome version
Chromium 109.0.5414.119 snap
Docker version and image (if applicable)
No response
Steps to reproduce the problem
import { sleep } from 'k6';
import { chromium } from 'k6/x/browser';
export default function () {
    const browser = chromium.launch({ headless: false });
    const page = browser.newPage();
    page.goto("https://k6.io/docs/javascript-api/xk6-browser/api/page/")
      .then(() => {
          sleep(30);
          console.log("After 30 seconds")
          console.log("After trying to goto k6 again")
          page.close()
          browser.close()
Expected behaviour
The browser should remain open
Actual behaviour
The browser closes automatically failing the test
Hi @george.l! Welcome to the forum!
In regards of your question, I believe the error is because you are mishandling the promise returned by the second call to page.goto. See my example on one option to do that:
    page
    .goto('https://k6.io/docs/javascript-api/xk6-browser/api/page/', { waitUntil: 'networkidle' })
    .then(() => {
        sleep(5);
        console.log("After 5 seconds");
        return page.goto("https://k6.io/docs/javascript-api/xk6-browser/api/browser/", { waitUntil: 'networkidle' });
    .then(() => {
        console.log("After trying to goto k6 again");
    .finally(() => {
      page.close();
      browser.close();
Another option is to use the latest released version of xk6-browser (v0.8.0) which has support for async / await API and the promises handling can be simplified. See an example:
export default async function () {
    await page.goto('https://k6.io/docs/javascript-api/xk6-browser/api/page/', { waitUntil: 'networkidle' });
    sleep(5);
    await page.goto("https://k6.io/docs/javascript-api/xk6-browser/api/browser/", { waitUntil: 'networkidle' });
    page.close();
    browser.close();
Let me know if that helps.
Regards.
Hey Daniel and thank you!
The issue persists in the first example you sent me if you change the sleep(5) to sleep(30). The browser seems to be closing after 30 seconds no matter the testing script!
Hi @george.l ,
I believe that is because by default chromium browser defines a default 30s timeout. See launch options. You can change that initializing the browser like:
        timeout: '1m', // Or whatever time you want to define
        headless: false
Let me know if that fixes the issue.
That did the trick. Thank you Daniel!
