I have a very strange issue when running the load tests using the browser extension, I’m experiencing browser connection resets.
It seems that the issue isn’t happening all the time, it happens randomly.
There are sufficient resources.
Can someone maybe help me with this I know it’s a general issue but I didn’t find any related logs that point to that issue.
It’s important to say that my client is not lightweight, it is pretty heavy in different scenarios.
It can be a factor of this reported browser resets?
It’s stopped us from using the k6 framework.
If someone can help me with this I’ll very appreciate it.
I can’t send full output of the test run it’s including sensitive data. Anyway there is no exception throw by k6 except of: time="2023-08-09T14:15:25Z" level=error msg="communicating with browser: websocket: close 1006 (abnormal closure): unexpected EOF" category=cdp elapsed="0 ms" goroutine=176
In the gist, the point that it seems the issue happans is in the promise. I also tried to remove the sleep.
This is usually a symptom of the issue, but not the issue itself. Can you remove the sensitive data and paste the full output, or at least the previous 5-10 lines before this error message you have pasted here.
Cheers,
Ankur
EDIT:
Could you also paste the full dockerfile that you are using to build the container image?
The primary issue seems to be with clicking on a selector "//i[@id='analysis-queries-grid-showAnalysisResults-btn']":
Uncaught (in promise) clicking on \"//i[@id='analysis-queries-grid-showAnalysisResults-btn']\": checking hit target: another element is intercepting with pointer action
I’ve seen this occur when trying to click on an element in an iframe. If that is the case then unfortunately the browser module doesn’t support iframes at the moment. You could try a workaround using page.evaluate, here’s a post that might help you: Locating elements within an iframe.
If the website under test is not working with an iframe then I will need to be able to test against the same website you are testing against or a publicly facing website which exhibits the same issue.
