I want to show mulitple column value like first name + last name in filter from different column from sql server and show the data according in th dashboard.
I don’t understand what you are trying to do. Can you give us an example?
Suppose in sql server there are 2 columns first name and last name…I want to show both the columns in one filter and use the variable,
