Vulnerabilities reported while Creating a new panel plugin V10
Greetings!
We have just installed the Grafana v10 on Windows platform with WSL while we tried to create a new panel plugin using @grafana/create-plugin its reported 32 Vulnerabilities as below.
We have tried with both node versions v16 and v18 still the initial scaffolding template reporting the vulnerabilities as follows:
How can we fix these vulnerabilities?
Thanks in advance
Welcome
Might want to try what it recommends?
Hi - please see this advice Bug: Many vulnerabilities found when creating a plugin · Issue #248 · grafana/plugin-tools · GitHub
These do not impact production builds. For me - running:
  • npx @grafana/create-plugin@latest
  • npm install
  • npm audit --omit-dev
results in:
found 0 vulnerabilities
Thanks David It works!!
