Visualization is missing on Grafana
I just started using Grafana, and was following a tutorial. I wanted to add a singlestat visualization to the panel I created but it’s missing. There’s no panel for visualization.
I checked if there’s anything I need to enable to see it but couldn’t find any. Please can anyone point me to the right direction.
Please note that singelstat is deprecated, use stat instead.
Hope it helps.
Good Luck
