Hi Guys
I wanted to do some network troubleshooting and noticed that I cant use a ping function with Telgraf data collector service.
So I decided to make my own, I thought I share with everyone, maybe it helps someone in the new future.
So here is goes:
I am using a Linux debian with my Grafana server and I use Influxdb with my Grafana.
However I did not know how to write in influx as the language is a tiny bit different to mysql.
SO I ended up installing mysql
apt-get install mysql-server
setup your users however you want and create the following database
CREATE USER âuserâ@âlocalhostâ IDENTIFIED BY âpasswordâ;
#change the user with your username and password with your desired password
GRANT ALL PRIVILEGES ON PingPlot.* TO âuserâ@âlocalhostâ IDENTIFIED BY âpasswordâ;
Create table ip_table(
id int not null auto_increment,
ip varchar(30) not null,
primary key (ID));
Create table ping_log (
log_time timestamp default current_timestamp,
ping_time decimal(6,2));
#Also donât forget to add indexes for the ping_log table to make it load faster
ALTER TABLE ping_log ADD PRIMARY KEY (ip,log_time,ping_time);
At this point I have created 2 scripts to ping IPs in different intervals. Since I have IP addresses that I want to monitor every minute and IP addresses that I want to monitor every hour. You might not need both.
Note that you can change the time in the script.
setup a script called localping.sh
vi localping.sh
save it
make sure its executable
chmod 755 local ping.sh
and paste the following in this script.
#!/bin/bash
#create the below file and put your root password in it
dbpw="$(cat /root/dbpw)"
ping_timeout=10 # in seconds
while read -a row
do
ip="${row[0]}"
[[ $ip = âipâ ]] && continue
# note: do 2 pings and only log the seconds one, since the first may fail
duration="$(ping -c2 -w$ping_timeout $ip | head -3 | tail -1 | cut -d'=' -f4 | cut -d' ' -f1)"
[[ $duration == "" ]] && duration="0"
echo "ip: $ip duration: $duration"
echo "INSERT INTO ping_log (ip, ping_time) VALUES ('$ip', $duration)" | /usr/bin/mysql PingPlot -u user -p"$dbpw"
done < <(echo âSELECT ip FROM ip_table WHERE location = âinternalââ | /usr/bin/mysql PingPlot -u user -p"$dbpw")
#End
last step is to make this run in the intervals that you want
edit crontab -e and make the following entry (paste it at the end)
***** /usr/share/scripts/localping.sh
This will run your localping.sh script every minute.
Note that I have placed my localping.sh in /usr/share/scripts
you can put it anywhere but make sure you reference it currently in here.
I hope the info I provided is helpful to the Grafana community
