Azure managed Grafana v10.4.7 -
I am creating dashboard with Azure metrics as data source. One of the parameter in my metrics datasource is Country name and this metrics contains data from all over the world. I want to restrict my dashboard to specific countries. I created a dashboard variable and hardcoded the country names I need with “multi select” and “include all option” enabled (Custom variable with comma separated country names).
If I select single country from the dropdown variable, I get the desired data. But if I select “All” in the drop down, graph shows data for every country available in the metrics (way more than what is listed in the variable). I want query to filter to restrict itself to the countries in the variable.
If I inspect the graph (under Json->Panel Data), I see every country and don’t see what parameter was passed to the query when “All” is selected. I tried searching up for options to try under “Custom all value” like “+” etc. I also tried putting hardcoded country list under “Custom all value” but that didn’t help.
Any ideas/clues what is going on here and how I can debug this better. I want to know what exactly is passed to the query when “All” option is selected from the drop down.
No errors. -
None. I tried the steps per Grafana documentation but that didnt help.
