I’m using Loki and Promtail with Nginx web servers (json format).
We can create variable based on log labels, it just works
Now, I would like to create a new variable based on the server_name field
With the json parser fields become labels, that’s why I guess it’s possible to create a such variable.
is there anyway to do that ?
Thanks for your help
So just to confirm, server_name is a label extracted from log content using parser (json | logfmt | regex), right? If so, no, there is currently no way how to create template variable based on label extracted from log content using parser.
Right, i’m using the json parser ({job="nginx-json",filename="/var/log/nginx/access_json.log"} | json)
Thanks for the reply
Does support for using label extracted from log message for dashboard variable is in the pipeline? or is it something that won’t be supported?
