tried them in the alert message filed can not the current value.
Total rentals: {${labels.Value}}.
Total rentals: {${labels.value}}.
Total rentals: {{.Value}}.
Total rentals: {{.value}}.
Total rentals: {${Value}}.
Total rentals: {${value}}.
Total rentals: {{value}}.
Total rentals: {{ $value }}.
is there a way to get the value in the alert message?
Grafana v8.2.5
it’s look like you are using the legacy alerting platform and not Unified Alerting. Is that correct @sonysadi?
handlebar templating like this should work with a multi-dimensional rule in Unified Alerting.
Yes, I am using the legacy alerting platform and not Unified Alerting.
And the Doc is not helpful about messaging templete
Thanks for the reply, I saw that old doc already,
But it does not tell how to print the gauge “value” of metrics in the notification template
