Using the Value of a Template Variable to Select Another Value
  • What Grafana version and what operating system are you using? 8.1.2
    I have a template constant that indicates which environment is being used. I will have dashboards set up in 3 different environments so the value of the environment variable will change can have the following values:
dev, int, prod
The Apis I am monitoring will have different domain names based on the environment selected.
For example, in Dev the domain name would contain “.m2d”, in Int is would be “.m2i”, and prod would be “.m2p”.
So when the value of the environment value is Dev, I would like to have another variable the will pick the right domain name subset.
If environment = “dev” then return “m2d”
if environment = “int” then return “mdi”
    I’ve attempted to work with template variables to achieve this. The “Custom” variable seems like the best match because it apparently lets you map values and return a different value. But I can’t get it work because the value I am using is a variable.
This is idea of the mapping I’m looking for:
($Environment.value==“dev”:“m2d”,$Environment.value==“int”:"m2i…)
  • What happened?
    I cannot get it to work.
    I expect to be able to pass in a variable to another template variable and have it return a value based on the value of the variable passed in.
    This isn’t a configuration issue.
    Templates and variables | Grafana Labs
