Using the global time range in all time series panels of a dashboard with selected time based on now
Is it possible to use the same global time range ($__from / $__to) in all time series panels of a dashboard when time based on now is selected? By default each panel (and query variable) calculates it’s own now time which leads to the different time ranges. So if i select data in my query variable based on the variable’s time range ($from / $to in case of clickhouse datasource) or the global time range ($__from / $__to) and then use it in panels queries, it will belong to a time range different from the panel’s time range ($from / $to). Or if i use the global time range ($__from / $__to) in the panel’s query, the selected data may go beyond the visible interval.
In my particular case i select top N time series in a query variable and then show different graphs on different panels for those time series only.
It looks like the problem could be solved by calculating now globally (only once) for the dashboard.
