I’m using template variables to query tags from an sql source before passing these tags to OpenTSDB to query the actual time series data. The issue is, if the SQL source returns a tag that doesn’t exist in opentsdb for some reason, the whole panel doesn’t work. Is there a way to disable specific metrics if the tag returned doesn’t exist?
Related topics
| Topic | Replies | Views | Activity | |
| Disable metric based on template variable | 4 | 1649 | January 6, 2021 | |
Possible to conditionally disable metric query?
0 | 1167 | February 13, 2019 | |
| How to make tag_values query work in Templating with OpenTSDB | 3 | 7756 | May 9, 2022 | |
| Template Variable in opentsdb metric | 8 | 3078 | August 21, 2019 | |
| Templating query on opentsdb not working? | 5 | 2491 | August 8, 2017 |
