Using infinity datasource in the panel plugin SimplePanel.tsx
Hi All,
I am starting to develop a panel plugin, and for now I am just focusing on the components, the SimplePanel.tsx. I don’t need the options part yet.
In the panel, I want to create a simple form with a submit button and a text field to display the response. The challenge I have is that I want to reach the infinity datasource on the click of the button and pass it a json payload with the form input, as a post request. Finally display the response message in the text field.
How would I with the javascript logic connect to my infinity datasource in the SimplePanel.tsx file. My infinity datasource has a call to an api with security added and it’s already configured.
Thank you guys in advance, any hint would be very helpful.
Hi @markomedin,
You can use the getDataSourceSrv().get() and getBackendSrv().fetch() functions to get a reference to the datasource and then make a post request to the backend respectively.
Something like this:
import { getBackendSrv, getDataSourceSrv } from '@grafana/runtime';
const datasource = await getDataSourceSrv().get(`your-datasource-id`);
const response = await getBackendSrv().fetch({
  method: 'POST',
  url: 'api/ds/query',
  data: {
    datasourceId: datasource.id,
    queries: [
        refId: 'A',
        queryType: 'query',
        query: 'your-query',
Let me know if you run into any issues.
