Update: I wanted to allow users to enter any query in dashboard and that is possible with just filters.
I want for users to be able to change constant template variable with any query and to use that query in panels. When I look in inspector whole variable is escaped, I’ll give example, for constant variable query_var value:
hostname.keyword: host-02
In query inspector I get query.data:
"query":"hostname.keyword\\:\\\"host\\-02\\\""
If I just type value in query field then query is:
"query":"hostname.keyword:\"host-02\""
So no extra escaping occurs.
Is there any way to turn off that escaping?
I would really like feature like this which would allow users to search logs from Grafana. So if there is not what should be changed to allow this?
