Using a math expression value in a classic condition
Hello Guys,
Appretiate any help with the below.
    8.2.2
    I am trying to pull the value of a math expression for an alert to create a classic condition to alert on.
  • What happened?
    I get the error: Failed to evaluate queries and expressions: failed to execute conditions: only data source queries may be inputs to a classic condition, E is a Expression
I was hoping it would let me use the math expression in my classic condition to fire an alert.
Welcome to the Grafana forum.
I think you can definitely achieve what you want, but maybe not using the Classic Condition. What is your datasource? It appears from your screenshot that you already have some queries working and presumably displaying your data. Can you post those here?
I have the same problem and want to use classic condition expression with math expression, grafana 8.3.3.
Use case:
Query A (elasticsearch) - Count(A)
Query B (elasticsearch) - Count(B)
Expression Math: Count(A) / Count(B) * 100 - to have percentage
Expression Classic Condition: When exp_math is Above X trigger alert
So simple and does not work.
I have the same problem once I upgraded to 8.3.3.
Anyone has news about this operations ?
I’ve also hit this same condition, and am unclear on how to work around it. Please advise, and thank you!
Sounds like this may help:
Adding a reduce and selecting last value allowed me to create an alert:
it worked for me:
Use case:
Expression Reduce A
Expression Reduce B
Expression Math: ($C * 100) / $D < 80
I have the same problem with 8.3.3.
