Using a Grafana Variable to control Y-Axis Max in the Time Series Plot (GraphNG)
    8.x
    In the Time-Series Plot, I am trying to use a Grafana variable as y-axis max across several panels in a dashboard. This would give the user an ability to select y-axis maximum range from a drop-down list of pre-determined values.
    Define a variable, use it’s name in the Max Field of the Time Series graph.
  • What happened?
    The maximum (or minimum) Field in the Time-Series plot does not allow '$" symbol that indicates variable. I am also suspecting that the time-series plot would support using a variable for this. The “old” graph did (somewhat) support it.
    I would have expected that the time series plot would be able to obtain the value of the variable to set said value to be the maximum range of the plotted data.
    No, this is easy to experience/see/duplicate on any time series plot.
    No, just unable to enter $variableName value into the max field of the time series graph.
    No. This is an obvious and intuitive operation.
