I would like to display in e.g. gauge graph what is in % the pass rate (from total). Due to that I have created 2 queries where the 2nd one should be in % of the 1st one.
In an video I have seen that this is possible but in my case it does not work and it is might because I am using influxDB?
Hi again,
sorry but can you perhaps help me as I really got stuck !
I have a query A which is showing me the number of successful builds
SELECT count("build_result") FROM "jenkins_data" WHERE ("project_name" =~ /^$project_name$/) AND ("build_successful" = '1') AND $timeFilter GROUP BY time($__interval) fill(null)
and than the query where it shows me the total number:
SELECT count("build_result") FROM "jenkins_data" WHERE ("project_name" =~ /^$project_name$/) AND $timeFilter GROUP BY time($__interval) fill(null)
now I would like to devide query A by query B to have the successful rate (which will be shown in % - as option)
than I have prepared several queries as single but none of them work, e.g:
SELECT (SELECT count("build_result") as "success" FROM "jenkins_data" WHERE ("project_name" =~ /^$project_name$/ AND "build_result" = 'SUCCESS') AND $timeFilter GROUP BY time($__interval) fill(null))/(SELECT count("build_result") as "total" FROM "jenkins_data" WHERE ("project_name" =~ /^$project_name$/) AND $timeFilter GROUP BY time($__interval) fill(null))
SELECT count("build_result") FROM (SELECT count("build_result") as "success" FROM "jenkins_data" WHERE ("project_name" =~ /^$project_name$/ AND "build_result" = 'SUCCESS') AND $timeFilter GROUP BY time($__interval) fill(null))/(SELECT count("build_result") as "total" FROM "jenkins_data" WHERE ("project_name" =~ /^$project_name$/) AND $timeFilter GROUP BY time($__interval) fill(null))
It is not in official grafana plugins repo, you’ll have to install it manually from github.
Don’t know how stable the plugin is, but it worked for me when I tried it.
SELECT 1 - mean("isFail") FROM (SELECT "build_result_ordinal"/"build_result_ordinal" AS "isFail" FROM "jenkins_data" WHERE ("project_name" =~ /^$project_name$/) AND $timeFilter) WHERE $timeFilter
Although this reply is quite late, this solution should be helpful for any future passers-by with a similar issue.
I see that you are using the Jenkins InfluxDB plugin, in which case, using the build_result_ordinal field can be used as a workaround for finding the success rate of a Jenkins build.
For reference:
Jenkins Build Status
SUCCESS
0
UNSTABLE
1
FAILURE
2
NOT BUILT
3
ABORTED
4
What’s going on in the query:
The SELECT "build_result_ordinal"/"build_result_ordinal" clause in the subquery normalizes the build_result_ordinal (bro) to:
bro/bro
SUCCESS
NaN
UNSTABLE
1
FAILURE
1
NOT BUILT
1
ABORTED
1
But InfluxQL can’t handle NaNs, so it just reports them as 0. (This may be changed: see github issue below)
So this subquery returns a list of ones and zeros, where 0 is Successful and 1 is Not Successful.
Then, by taking the mean of this list we can find the failure rate of the Jenkins builds, and then subtract this from 1 to get the success rate of your Jenkins jobs with the InfluxDB plugin.
Useful Resources:
Extra Queries!
If you want an unstable build to count as a “successful” build for reporting in Grafana, the query you need is:
SELECT 1 - mean("isFail") FROM ( SELECT ceil(("build_result_ordinal"-1)/("build_result_ordinal")) AS "isFail" FROM "jenkins_data" WHERE $timeFilter) WHERE $timeFilter
for InfluxDB v1.6+, and
SELECT 1 - mean("isFail") FROM ( SELECT ((("build_result_ordinal"-1)/("build_result_ordinal"))/(("build_result_ordinal"-1)/("build_result_ordinal"))) AS "isFail" FROM "jenkins_data" WHERE $timeFilter) WHERE $timeFilter`
