I use Grafana with oidc authentication. For some users my userinfo endpoint returns json with
attributes property in the format:
"attributes": "{\"propety\":[\"propertyValue\"]}"
Grafana fails with the deserialization of this property with error:
cannot unmarshal string into Go struct field UserInfoJson.attributes of type map[string][]string
I want Grafana to ignore this property in my case. Is there any protocol standard which says that attributes property must be in format map[string][]string ? I haven’t found anything like that.
Environment :
- Grafana v7.2.0-pre
- IdentityServer4 OIDC authentication
