User variable so each user may different results
Is there a way to create a user variable so each individual will see different results on a dashboard?
For example: Several people will give someone feedback though a survey and I would like that person to have a login to see the results of their feedback as shown in the attached image.
This is popular feature request but not implemented / on roadmap yet
Thanks. Maybe I can add the feature.
Hello Torkel,
I see many requests for this feature and it should be quite simple to implement.
Any reason it is not on the roadmap ?
I vote for it :wink:
Hi Torkel,
any possibility to add this item in roadmap ?
I have been reading the different issues in github related to this. In particular I was exited to see this one progressing Dashboards: allow string manipulation as advanced variable format option (fix #8259) by rscot231 · Pull Request #29754 · grafana/grafana · GitHub
but it got to a stop… I understand it was crazy. @torkel
I was wondering whether the following option has been considered:
  1. Allow variable interpolation in “Constant” variable (OK, maybe add another variable type that looks just like “Constant” but with variable interpolation active). For example, this should work:
    Value: ${__user.login}
  2. Allow “Regexp”. Then for a user login handle “pedro_perez” the following would produce
      Regex: /\w+[_](?<value>[\w]+)/g
      Preview of Values
      perez
Thanks for your attention
