grafana:7.4.0 inside k8s Cluster (v1.18.17-gke.1901) -
we have below metrics from prometheus:
operations_aws_provisioning_succeeded_total
upgrade_cluster_result{plan_id="1111"}
operations_azure_provisioning_succeeded_total
upgrade_cluster_result{plan_id="2222"}
We would like to have one custom variable with values:
e.g. variable: plan_id with values aws : 1111, azure : 2222
And created query template using above custom variable
upgrade_cluster_result{plan_id="$plan_id"}
operations_${plan_id.key}_provisioning_succeeded_total
Am trying to obtain customer variable’s key inside a query expression
operations_${plan_id.key}_provisioning_succeeded_total -
What happened?
Didn’t find a way to obtain the key for a custom variable inkey : valuepairs formate inside a query expression
How can we get the variable keys (aws, azure) inside a query expression
Add a custom variable | Grafana Labs
