Is there a way to customize the dashboard URL to scroll to a specific row in a dashboard?
My specific use case is that I have a dashboard which uses data links to link to itself with specific variables applied. I imagine it’s a pretty common use case, but there’s a table which is a list of devices, and another panel which shows time series data for one specific device. Clicking the table selects the device you want to look at. Problem is that the time series panel is down off screen when you’re looking at the table of devices, so you have to click the table and then scroll to go look at your data. Would be much better if I could set the data link to automatically shift focus to the time series panel. Is this possible?
