Upload xlsx file to API
I’m trying to upload xlsx files to API using POST request. Here my code
let fileContent = open("./files.xlsx");
// Authorization
export function setup() {
  return {
    token: getToken(),
export default function (config) {
  const params = {
    headers: {
      Authorization: `Bearer ${config.token}`,
      "Content-Type": "application/octet-stream",
let url =
    baseUrl +
    "bsp-ins-ref/api/standard-element-referential/vehicle-range/92eca041-a1eb-4e3f-8996-40f8267f52be/initialize-referential";
  var res = http.post(url, fileContent, params);
  check(res, {
    "Upload Excel 200": (res) => res.status === 200,
Unfortunatly it doesn’t work, i have this error “Cannot deserialize the current JSON object”. I have the same issue with postman.
Thanks you in advice for your help.
This is an error you see from the system you are testing, not from k6, right? Because I don’t think k6 emits such an error and I don’t see you doing anything with JSON in your script…
If so, then the only issue I can see with your script is the fact that you should probably open() the excel spreadsheet as a binary file, like this:
let fileContent = open("./files.xlsx", "b");
I’m not sure that this error is from k6. I already tried to open my excel spreadsheet as a binary files, and it doesn’t work either :confused:
Well, please paste the full error, with the stacktrace and all. Or a screenshot of the terminal window where you see it. This error string literally isn’t present in k6 and its dependencies or Go, but I can’t help you without more context and details…
Thank you for your help. I found my mistake. They send encoded base64 files. I didn’t realize it after a while
