How should I deal with k6/experimental/fs?
I’m trying to replace default open() with fs.open() to use with http.file().
But I’m stacked on how to provide []byte or ArrayBuffer object to http.file().
My simplified scripts is
import http from 'k6/http';
import { check, fail } from 'k6';
import { FormData } from 'https://jslib.k6.io/formdata/0.0.2/index.js';
import exec from 'k6/execution';
import { open } from 'k6/experimental/fs';
let EXCEL_FILE_BIN
let FILE
(async function () {
    FILE = await open('./test.xlsm');
async function readAll(file) {
const fileInfo = await file.stat();
const buffer = new Uint8Array(fileInfo.size);
const bytesRead = await file.read(buffer);
if (bytesRead !== fileInfo.size) {
    throw new Error(
    'unexpected number of bytes read; expected ' +
        fileInfo.size +
        ' but got ' +
        bytesRead +
        ' bytes'
return buffer;
async function get_bin_file(file) {
    file_bin = await readAll(file);
    return file_bin
    EXCEL_FILE_BIN = await get_bin_file(FILE);
console.log(JSON.stringify(EXCEL_FILE_BIN));
const form_data = new FormData()
form_data.append('file', http.file(EXCEL_FILE_BIN, 'k6 test.xlsm', 'application/vnd.ms-excel.sheet.macroenabled.12'))
So I get error at form_data.append
INFO[0001] undefined                                     source=console
ERRO[0001] GoError: invalid type <nil>, expected string, []byte or ArrayBuffer
        at go.k6.io/k6/js/modules/k6/http.(*ModuleInstance).file-fm (native)
        at file:///Volumes/work/Yandex.Disk.localized/aurora/repos/aurora_k6/project-tests.js:56:67(122)  hint="script exception"
I’m not very familiar with JS and am probably doing something wrong?
Hello @nktedo001 You need to define main function which k6 can run as default function where you can put all vus operations FormData and read files. See example below
let EXCEL_FILE_BIN
let FILE
    FILE = await open('sample.pdf');
        throw new Error(
            fileInfo.size +
            ' but got ' +
            bytesRead +
            ' bytes'
    return buffer;
export default async function () {
    EXCEL_FILE_BIN = await readAll(FILE);
Also file extension changed to pdf but when using .xlsm error appear.
Hey, thanks for the reply.
Oh, I should have clarified that using it in INIT stage is to prepare form data once and share it in the tests.
@nktedo001
You can try this way:
let EXCEL_FILE_BIN;
let FILE;
const form_data = new FormData();
    throw new Error(
      fileInfo.size +
      ' but got ' +
      bytesRead +
      ' bytes'
  return buffer;
  console.log(JSON.stringify(form_data));
Thank you!
This one worked.
With fs module k6 has now not exceeded memory usage!
Great job!
