Upgrade from Grafana v7.1.0 (8101355) to latest version
May I know who can lead me to the steps on doing this?
  • What Grafana version and what operating system are you using? v7.1.0 ([8101355]
  • What are you trying to achieve? Upgrade
  • How are you trying to achieve it? Upgrade
  • What happened? Upgrade
  • What did you expect to happen? Upgrade
  • Can you copy/paste the configuration(s) that you are having problems with? Upgrade
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No
Hi @kimcagayat ,
Here is the link to the documentation to help you upgrade your Grafana instance.
If this does not help, feel free to let us know.
Thanks Antonio. Can we proceed with updagrade from 7.1 to 8.1 directly without any issues?
Hi @kimcagayat
You should first read through breaking changes to know what to expect. There are a lot of differences between major version upgrades, from 7 - 9 .
Hi Antonio, thanos for your feedback. I upgraded from 7.1 to 8.1. I noticed that the Azure Log Analytics Datasources are no longer configurable. Please see screenshots:
Before:
After:
Can you please help advise on how I can remediate this?
Hi @kimcagayat
Is that menu needed for the azure monitor datasource to work in the Grafana version you just installed? As far as I have read in the 7.1 azure docs , the menu was there for writting your credentials. Currently, the two configuration methods (i.e. authentication/credentials) for the Azure plugin are via Azure AD App Registrations or using managed entity . So, perhaps that’s all you need to keep in mind.
In Grafana v9.2.2.the menu is not included either. I hope the data source works correctly despite the missing menu.
