Understanding the Calculation of Stream Limits in Loki Ingesters
One of my tenants has been increasing the number of streams, which has led to a noticeable increase in the loki_ingester_memory_streams metric. and This increase has also impacted some other tenants, causing them to receive 429 (Too Many Requests) errors.
All these tenants are coming from a single log shipper, so they share the same ingestion pipeline.
To mitigate the issue, I increased the max_global_streams_per_user limit, which has partially fixed the problem.
However, my concern is that the limit is calculated as follows:
(global limit / number of ingesters) * replication factor
My question is:
Is this calculation applied globally across all tenants in Loki’s ingester, or is it specific to each individual tenant across all ingesters?
In other words, does this calculation consider the global limit for all tenants, or does it treat each tenant separately when distributing the limit across ingesters?
i saw this config before
# Maximum number of active streams per user, per ingester. 0 to disable.
# CLI flag: -ingester.max-streams-per-user
[max_streams_per_user: <int> | default = 0]
# Maximum number of active streams per user, across the cluster. 0 to disable.
# When the global limit is enabled, each ingester is configured with a dynamic
# local limit based on the replication factor and the current number of healthy
# ingesters, and is kept updated whenever the number of ingesters change.
# CLI flag: -ingester.max-global-streams-per-user
[max_global_streams_per_user: <int> | default = 5000]
but i do not understand it. I would appreciate it ifyou could help me figure this out.
What I expected:
I expected that the tenant that increases the streams would be the one limited, and not other tenants. Ideally, the increase in streams for one tenant should only impact that tenant, rather than affecting all tenants using the same log shipper.
I think your problem is with your log shipper. For example, let’s say you have 1000 logs in your log shipper ready to be shipped, and the first 10 get 429 because of rate limiting, I doubt the shipper would cycle through the rest of 990 messages because it would be reasonable to assume the rest of logs would fail to send too (from the shipper’s perspective) and it’s inefficient. You can test this easily by performing an ad-hoc API call to your Loki cluster while your tenant is rate limited.
