Hello All,
I am runnuing grafana opensource ( version 9.5.1) on " [debian-11-bullseye-v20230411]" . I want to achieve that users should change the password after 15 days. So, I have added below lines under “security” section of grafana.ini file. But, still is not working .
[security]
password_auto_expire = true
password_expiry = 1296000
Please help here.I am providing same information here in expected template form.
Operating system: debian-11-bullseye-v20230411
Grafana version: Opensource , 9.5.1 -
I want to achieve that users should change the password after 15 days -
By adding below lines in “security” section of grafana.ini file.
[security]
password_expiry = 1296000 -
What happened?
Grafana is not asking users to change the password after 15 days. -
Grafana should ask users to change the password after 15 days. -
[security]
No -
Yes
