version 8.5 -
Select other timestamp in Date histogram -
What happened?
try but not allow to select other filed except TimestampasDate -
In the data source, I have 4 columns with 4 different timestamp(pic1), I would like to pick either 3 to groupby except TimestampAsdate in Date histogram.
However, the only one available(pic2) to check is TimestampAsdate, why? How to deal with it? -
Yes -
No -
Those are epoch timestamp, you might need to convert them to real date time
Thanks for the reply, I know how to use date transformation in Grafana. In that way, I can’t use date tohisgram function. Are you suggest me to convert it before I pull data from database? Because I am user to build the dashboard, I do not have permission to update that in the raw data. Any other suggestion?
