Hello Team, Am using grafana monitoring tool for last one year and now the server which runs Grafana goes down and we are unable to monitor the traffic. And i have installed Zabbix server and installed grafana plugin with Zabbix. But after installing the Grafana only one time i have got the traffic from the host. And still now not getting any traffic to Grafana. Can you please help me to fix it.
Is zabbix collecting the data ? In grafana > Datasources HTTP Settings are ok? Check if the username:password of the zabbix api are correct, and if the user you are using has the correct permissions (in zabbix to READ-write) on the host you want to collect data from.
Hi, Getting data from Zabbix server properly now. Thank you.
