Hi , I have recently created an alert rule(grafana 9.1.4) for a panel(in a dashboard) manually from UI. Now I have done the following to fetch the alert rule using HTTP API.
Used /api/prometheus/grafana/api/v1/alerts HTTP API to fetch “all” the alert rules(had to use this API due to this issue). Below is the snippet of the alert config from the output that i have configured manually as i mentioned above.
"labels": {
"alertname": "canada-shards",
"grafana_folder": "mongo-volume-iops",
"rule_uid": "canada_mongo_disk"
"annotations": {
"__dashboardUid__": "Kh7igLA4z",
"__panelId__": "2",
"description": "canada mongo vol iopps > 90%"
"state": "Normal",
"activeAt": "0001-01-01T00:00:00Z",
"value": ""
Now I got the “rule_uid” of the configured alert rule from step 1 and ran /api/v1/provisioning/alert-rules/canada_mongo_disk which gives me this error below :
"message": "could not find alert rule",
"traceID": "00000000000000000000000000000000"
I don’t understand why I keep getting this error though I am using the correct api to fetch the alert by it’s rule_uid.
BTW, When I try the same steps above for migrated dashboards and alerts(from previous grafana version). it works fine. I am able to fetch the alert by it’s rule_uid.
I am seeing this issue only for newly created alerts in current grafana version(9.1.4).
Below is the alert rule_uid I configured as a label from UI. Is this the rule_uid that it is referring to ? Anything I am missing here.
To me this feels like a bug. Please confirm if this is a bug indeed or please let me know of a work around. I am currently blocked.
Also how is alert “rule_uid” is created when an alert is manually configured from UI. I just gave a label “rule_uid” as key and a value for it. I use this key value pair to map it to notification policy.
