Hi @blaZe
Welcome to the community forum
What your endpoint returns seem to not be an ISO standard date. If you were able to get that from your endpoint, I believe const timestamp = Date.parse('2023-07-12T03:17:36.000Z') would work. What does not work is getting a Timestamp from a custom date format like Jul 12, 2023 3:17:36 AM.
We discussed this internally, and we don’t think this is working in the browser as standard JavaScript behavior. Browsers implement quite a lot of additional functionality, and that could be part of it. The specification does not forbid supporting additional formats. However, there is only one format that is required to be supported.
Date.parse() - JavaScript | MDN goes into some more details, and it is not expected to be working and will need to be added to goja, which is what k6 uses to interpret the JS scripts and execute them in the go runtime.
That said, the code would work with a date in a standard format, so if you were able to configure the request to return that, the following code would work:
const dateDiff = (ds1, ds2) => {
const d1 = Date.parse(ds1);
const d2 = Date.parse(ds2);
const timeDiff = d2 - d1;
return timeDiff / 1000;
export default function () {
const ds1 = '2023-07-12T03:17:36.000Z';
const ds2 = '2023-07-12T03:18:22.000Z';
console.log("diff:", dateDiff(ds1,ds2));
If you are probably not able to do that, until there is an option to parse dates specifying a custom format, and goja implements it, we’d suggest parsing this format in a function in your script. Which you can later replace if this becomes available. Something like this (better packaged and adjusted for your case):
function getMonthIndex(monthString) {
const months = [
'Jan', 'Feb', 'Mar', 'Apr', 'May', 'Jun', 'Jul', 'Aug', 'Sep', 'Oct', 'Nov', 'Dec'
return months.indexOf(monthString);
function parseDate(dateString) {
const dateParts = dateString.split(' ');
const month = getMonthIndex(dateParts[0]);
const day = parseInt(dateParts[1].replace(',', ''));
const year = parseInt(dateParts[2]);
const time = dateParts[3];
const hour = parseInt(time.split(':')[0]);
const minute = parseInt(time.split(':')[1]);
const second = parseInt(time.split(':')[2]);
const isAM = dateParts[4] === 'AM';
return new Date(year, month, day, hour + (isAM ? 0 : 12), minute, second);
function dateDiff(date1, date2) {
return (parseDate(date2) - parseDate(date1)) / 1000;
const ds1 = 'Jul 12, 2023 3:17:36 AM';
const ds2 = 'Jul 12, 2023 3:18:22 AM';
console.log("diff:", dateDiff(ds1, ds2));
I haven’t tested that, as k6 has limited support for node modules, though you might also try importing the moment module and see if that works for you. It seems to include js-joda and probably parsing specifying a custom date format.
I hope this helps
Cheers!
