Two Queries in One
Hi Guys!
How can i add two pattern queries in one.
For example y I have this count.
Query One
sum(count_over_time({app="nginx-ingress-microk8s-controller", namespace="ingress"} | pattern `<remote_addr> - - [<time_local>] "<method> / HTTP/<http_version>" <status> <body_bytes_sent> "-" "<user_agent>" <request_time> <query_time> [<referer>] [] <pod_ip>:<pod_port> <server_response_time> <_> <_> <log_id>` | user_agent="curl/8.1.2" | referer=`app-dominio-app-dominio-80` [$__interval]))
And the another one is:
Query Two
sum(count_over_time({app="nginx-ingress-microk8s-controller",namespace="ingress"} | pattern `<remote_addr> - - [<time_local>] "<method> <request> HTTP/<http_version>" <status> <body_bytes_sent> https://mi-dominio.dominio.com/ "<user_agent>" <request_time> <_> <_> <_> <status_ingress> [<resource_name>] <_> <_> <_> <log_id>` | method="GET" [$__interval]))
How can i sum both to have the total?
PD: The idea of each query is to count the number of GETs on domain. They are different because the domains are different and because the clients are different.
I understand that the structure is like this:
sum(count_over_time([$__interval]))
Once I get each one right, I would want to do something like this: sum(if QUERY1 OR QUERY2 happend)
I am ok?
Guys! I was trying.
Both queries alone work fine!
| pattern `<remote_addr> - - [<time_local>] "<method> <request> HTTP/<http_version>" <status> <body_bytes_sent> "<referer>" "<user_agent>" <request_time> <_> <_> <_> <status_ingress> [<resource_name>] <_> <_> <_> <log_id>`
| method=`GET` |  referer=`https://mi-dominio.xxx.com/`
another
| method=`GET` |  referer=`app-dominio-app-dominio-80`
But i can count both in the same query.
I want to count to create a timeline dashboard…
Example:
| pattern `<remote_addr> - - [<time_local>] "GET / HTTP/<http_version>" <status> <body_bytes_sent> "-" "<user_agent>" <request_time> <query_time> [<referer>] [] <pod_ip>:<pod_port> <server_response_time> <_> <_> <log_id>`
| referer="app-dominio-app-dominio-80"
[$__interval]))
Thanks!
Can you try ‘Transform’ → ‘Add filed from calculation’
Thanks @gvln5241 .
What do you think of the Queries? To count and sum the GET’s within the interval?
Thanks!
Take a look, if i copy your solution.
The result of Query A its 1, Query B its 13.
I think i need to change the output of the query to a number! Not?
When i choose the fields for the operation, only have {} and time.
Thanks @gvln5241
yes, NaN = Not a Number.
Can you convert to Number type (before using ‘Add field from calculation’ transformation)
And you can change the names also for readability.
