Anybody please help me. is there any possibility to use Vue js for Grafana plugin development.
the docs says
https://grafana.com/docs/plugins/developing/development/#what-languages
What languages?
Since everything turns into javascript it’s up to you to choose which language you want. That said it’s probably a good idea to choose es6 or typescript since we use es6 classes in Grafana. So it’s easier to get inspiration from the Grafana repo if you choose one of those languages.
I suppose it’s possible to change the framework. here are a example
OK thanks for your reply.let me create a plugin using vue js
