version: '3'
services:
web:
build: .
container_name: grafana
ports:
- "9000:3000"
expose:
- 9000
volumes:
- .:/newvolebs
networks:
- overlay
environment:
MYSQL_HOST: mysql
MYSQL_DATABASE: grafana
MYSQL_USERNAME: root
MYSQL_PASSWORD: 12345
mysql:
image: mysql:5.6
ports:
- "3306:3306"
expose:
- 3306
volumes:
- newvolebs:/var/lib/mysql
networks:
- overlay
environment:
MYSQL_ROOT_PASSWORD: 12345
volumes:
newvolebs:
driver: local
networks:
overlay:
driver: "bridge"
and my dockerfile is
FROM centos:centos7
RUN useradd centos && \
yum install -y sudo && \
echo "centos ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers
USER centos
ENV PATH="/home/centos/go:${PATH}"
RUN sudo cd /home/centos && \
sudo yum -y update && \
sudo yum --setopt=tsflags=nodocs -y install \
wget \git \
gcc-c++ make \tar && \
sudo wget https ://storage.googleapis.com/golang/go1.11.2.linux-amd64.tar.gz && \
sudo tar -xzvf go1.11.2.linux-amd64.tar.gz && \
sudo mv go gocode && \
curl --silent --location https :// rpm.nodesource.com/setup_9.x | sudo bash && \
sudo yum -y install nodejs && \
yum clean all && \
sudo chmod 666 ~/.bashrc && \
sudo echo "export GOROOT=$HOME/gocode" >> ~/.bashrc \
&& sudo echo "export PATH=$PATH:$GOROOT/bin" >> ~/.bashrc \
&& sudo echo "export GOPATH=$HOME/go" >> ~/.bashrc \
&& sudo echo "export PATH=$PATH:$GOPATH/bin" >> ~/.bashrc && \
PATH="${GOROOT}/bin:$PATH}" && \
export GOPATH=/home/centos/go && \
export GOROOT=/home/centos/gocode && \
source /home/centos/.bashrc && \
sudo mkdir -p $HOME/go/{src,pkg,bin} && \
cd $GOPATH/src && \
go get github.com/grafana/grafana && \
cd $GOPATH/src/github.com/grafana/grafana && \
go run build.go setup \
go run build.go build && \
npm install -g yarn && \
yarn install --pure-lockfile && \
yarn watch && \
cd go/src/github.com/grafana/grafana/bin/ && \
grafana-server \
echo "[main_settings]" > /var/www/html/config.ini \
&& echo "headerTitle='Dashboard'" >> /var/www/html/config.ini \
&& echo "encryptKey='ffgfjhvjhvjcfgfjj'" >> /var/www/html/config.ini \
&& echo ";Timezone Setting. ex: 'America/New_York'" >> /var/www/html/config.ini \
&& echo "defaultTimezone=''" >> /var/www/html/config.ini \
&& echo ";Database parameters for system usage (Should not be used by custom dashboard/charts)" >> /var/www/html/config.ini \
&& echo "dashboardDatabaseServer=mysql" >> /var/www/html/config.ini \
&& echo "dashboardDatabaseName=dashboard" >> /var/www/html/config.ini \
&& echo "dashboardDatabaseUserName=root" >> /var/www/html/config.ini \
&& echo "dashboardDatabasePassword=12345 >> /var/www/html/config.ini \
&& echo ";grafana credentials" >> /var/www/html/config.ini \
&& echo "grafanaDatabaseServer=mysql" >> /var/www/html/config.ini \
&& echo "grafanaDatabaseName=grafana" >> /var/www/html/config.ini \
&& echo "grafanaDatabaseUserName=root" >> /var/www/html/config.ini \
&& echo "grafanaDatabasePassword=12345" >> /var/www/html/config.ini && \
EXPOSE 9000
WORKDIR /home/centos
