I am using a plugin from OCS portal which is currently in development. I am trying to visualize the movement of a collar data using latitude and longitude values using Track Map panel.
I can see that the query retrieves the data properly as below:
whereas when we see the data ,it removes the decimal part of the latitudes and longitudes mainly.
How can we allow the query to consider the decimal values in it?
This problem is only with this panel. If I plot a graph, all the decimal are visible or atleast there is option in the panel to allow the number of decimal values.
Have any one faced this issue? Any solution please ? Can we edit the panel json to allow the decimal values of coordinates?
