Bonjour ![]()
Alloy: `v1.12.0`
Traefik: `3.6.4`
I have an Alloy receiver on VPS. And all others Alloy send to it logs, metrics, traces…
On my VPS who host Alloy receiver. I have Traefik who manage DNS with basicauth middleware to receive traces. something like: https://alloyfortraces.domain.tld
traefik.http.routers.alloytraces.rule: Host(`alloyfortraces.domain.tld`)
traefik.http.routers.alloytraces.entrypoints: https
traefik.http.routers.alloytraces.middlewares: default@file,alloyreceivertracesauth
traefik.http.routers.alloytraces.tls: true
traefik.http.routers.alloytraces.tls.certresolver: myresolver
traefik.http.routers.alloytraces.service: alloytraces
traefik.http.services.alloytraces.loadbalancer.server.port: 4317
traefik.http.middlewares.alloyreceivertracesauth.basicauth.users: traces:xxxxxxxxxx
But I have this error on all VPS with an Alloy sender instance:
{“ts”:“2025-12-16T09:57:19.036700838Z”,“level”:“info”,“msg”:“Exporting failed. Will retry the request after interval.”,“component_path”:“/”,“component_id”:“otelcol.exporter.otlp.tempo”,“error”:“rpc error: code = Unavailable desc = connection error: desc = \“transport: Error while dialing: dial tcp: address traces.domain.tld: missing port in address\””,“interval”:“15.819726413s”}
Alloy traces receiver configuration:
otelcol.receiver.otlp "default" {
http {}
grpc {}
output {
metrics = [otelcol.processor.batch.default.input]
logs = [otelcol.processor.batch.default.input]
traces = [otelcol.processor.batch.default.input]
otelcol.processor.batch "default" {
output {
metrics = [otelcol.exporter.otlp.tempo.input]
logs = [otelcol.exporter.otlp.tempo.input]
traces = [otelcol.exporter.otlp.tempo.input]
otelcol.exporter.otlp "tempo" {
client {
endpoint = "tempo:4317"
tls {
insecure = true
And Alloy traces sender configuration:
http {}
grpc {}
output {
output {
client {
endpoint = "https://alloyfortraces.domain.tld"
auth = otelcol.auth.basic.xxx.handler
otelcol.auth.basic "xxx" {
username = "traces"
password = "xxxx"
On localhost with Alloy sender and receiver at same time, no problem.
Same for metrics and logs, no problem behind reverse proxy.
Why needed of port for traces? I missed something in configuraion, what?
Thanks!
