Traces plugin not available
Greetings
Does this plugin no longer work
Hi @yosiasz,
Is it not available OR available but does not work?
got mixed up with your post title :slight_smile:
:laughing: purposely done so that it gets attention, and it worked.
When you click on it, nothing happens. just blank screen
Hey @yosiasz,
I kinda forgot on this one lately.
So I checked this plugin and it is a core plugin installed by default.
However, after some research, I found that this plugin (which is a Visualization plugin) is basically used with Tempo datasource for logs.
This is the link I found:
I hope this helps.
