Total value still showing when using sum by, how to remove?
v10.1.5
Grouping by label
sum(
rate(container_cpu_usage_seconds_total[15m]))
by (namespace)
  • What happened?
The total is still showing in the graph.
I would expect only a graph for each namespace. How can I remove the total from the graph?
sum(
by (namespace)
No
No
Here is the graph:
Why is it still showing the total? I only want to have a line per namespace.
What I have found working is exclude empty values from the label used in sum by.
sum(rate(container_cpu_usage_seconds_total{namespace!=""}[15m])) by (namespace)
This effectively removes the time series with the aggregated value.
