Install a full LGTM observability stack in a kubernetes cluster
Installing the lgtm-distributed helm chart v2.1.0 -
What happened?
All components are installed and are running, but when I try to access the Mimir or Loki datasources from grafana, I get a too many unhealthy instances in the ring error
This to work
- Can you copy/paste the configuration(s) that you are having problems with?
grafana:
enabled: true
datasources:
datasources.yaml:
apiVersion: 1
datasources:
- name: Loki
uid: loki
type: loki
url: http://{{ .Release.Name }}-loki-gateway
isDefault: false
- name: Mimir
uid: prom
type: prometheus
url: http://{{ .Release.Name }}-mimir-nginx/prometheus
isDefault: true
- name: Tempo
uid: tempo
type: tempo
url: http://{{ .Release.Name }}-tempo-query-frontend:3100
isDefault: false
jsonData:
tracesToLogsV2:
datasourceUid: loki
lokiSearch:
datasourceUid: loki
tracesToMetrics:
datasourceUid: prom
serviceMap:
datasourceUid: prom
loki:
enabled: true
mimir:
enabled: true
alertmanager:
enabled: true
replicas: 1
resources:
requests:
cpu: 20m
persistentVolume:
enabled: false
compactor:
resources:
requests:
cpu: 20m
persistentVolume:
enabled: false
distributor:
resources:
requests:
cpu: 20m
ingester:
replicas: 1
zoneAwareReplication:
enabled: false
resources:
requests:
cpu: 20m
persistentVolume:
enabled: false
overrides_exporter:
resources:
requests:
cpu: 20m
querier:
replicas: 1
resources:
requests:
cpu: 20m
query_frontend:
resources:
requests:
cpu: 20m
query_scheduler:
replicas: 1
resources:
requests:
cpu: 20m
ruler:
resources:
requests:
cpu: 20m
store_gateway:
enabled: false
resources:
requests:
cpu: 20m
persistentVolume:
enabled: false
minio:
resources:
requests:
cpu: 20m
persistence:
storageClass: gp2
rollout_operator:
resources:
requests:
cpu: 20m
tempo:
enabled: true
ingester:
replicas: 1
grafana-oncall:
enabled: false
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
In grafana UI “too many unhealthy instances in the ring”.
I can’t see any other error in the logs of the pods. And this is the status reported by mimir
- Did you follow any online instructions? If so, what is the URL?
