For both MSSQL and MYSQL databases there is the same error in graphs and alarms. You can see in the screenshot that i have databases with a time column. When i select UTC or my local time it doesn’t matter and graph shows 3 hours forward. If i select UTC in dashboard and settings data is ok and graph is also ok but in this case the timepicker is working wrong. I have this problem from the version 6.0 and still have the same problem.
