Hi there! I’m completely new to grafana, and want to display values from a timescaledb in grafana: The data looks like this:
I just dont know how I can transform time and date into the grafana variables for time. Can somebody help?
If you can change your data source to insert timestamp series as in this example :
https://docs.timescale.com/latest/introduction/data-model
It would be better integrated, i’ll try to check a workaround for that.
Hope it helps
