The thresholds are missing in the visualization
I’m using the “Gauge” visualization to display the usage percentage of a file system.
An example of a file system configuration :
I’m having a problem; I can’t get the thresholds I added to appear.
My thresholds
I feel like he doesn’t take into account the thresholds
Thank you for your help.
Check Color scheme set to (From thresholds (by value))
set thresholds
Make sure you calculate % correctly and then apply thresholds like this.
also use transformation(Add field from calculation) to calculate % then apply thresholds on that fields.
Thanks for your reply.
If I use Data source: Grafana and Query type: Random Walk, I can see the thresholds.
But if I use, Data source: tribe-29-checkmk-datasource, the thresholds appear at the beginning.
I select my Site, Hostname, Service and Graph type: single metric, the thresholds are still there
When, i select Single metric: Used space %, the thresholds disappear!!
My gauge conf:
if you have an idea…
Regards
I worked around the problem a little by adding some value mappings
and here’s the result:
It’s not perfect, but it’s better than nothing.
In any case, if you have any idea why I can’t see the thresholds appear, I’m interested.
Regards
