The moduleSpecifier \"/tests/load.js\" couldn't be found on local disk
Need help with the issue on gtilab-ci pipeline.
my docker-compose file looks like this:
version: ‘3.8’
networks:
k6:
grafana:
services:
influxdb:
image: influxdb:1.8
networks:
- k6
- grafana
ports:
- “8086:8086”
environment:
- INFLUXDB_DB=k61
grafana:
image: grafana/grafana:9.3.8
networks:
- grafana
ports:
- “3000:3000”
environment:
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_BASIC_ENABLED=false
volumes:
- ./grafana:/etc/grafana/provisioning/
k6:
image: grafana/k6:latest
networks:
- k6
ports:
- “6565:6565”
environment:
- K6_OUT=influxdb=http://influxdb:8086/k6
volumes:
- ./resources:/jmanager
- ./resources:/resources
- ./tests:/tests
- ./utils:/utils
my gitlab-ci.yaml file looks like this:
stages:
  • test
load_test:
stage: test
image: docker:latest
services:
- docker:dind
script:
- docker-compose --file=k6/compose.yaml up --build -d
- docker-compose --file=k6/compose.yaml run k6 run /tests/load.js
- docker-compose --file=k6/compose.yaml down --remove-orphans
tags:
- eks-tooling-generic
When it trying to execute this command “docker-compose --file=k6/compose.yaml run k6 run /tests/load.js” it shows the error that file cannot be found.
$ docker-compose --file=k6/compose.yaml run k6 run /tests/load.js
79time=“2024-03-25T10:42:02Z” level=error msg="The moduleSpecifier "/tests/load.js" couldn’t be found on local disk. Make sure that you’ve specified the right path to the file.
Could someone help me to solve this error? Why it cannot see my load.js file? Locally everything works as expected.
