I am able to run K6+InfluxDB+Grafana in Docker containers, but influxdb is only getting recognized in containers. I have mounted these with localhosts as well. But i can’t open localhost:8086 which says 404 not found.
I am getting this error inside the containers. grafana_1 | t=2020-10-10T12:55:44+0000 lvl=info msg=“Request Completed” logger=context userId=0 orgId=1 uname= method=GET path=/api/datasources/proxy/1/query status=502 remote_addr=192.168.48.1 time_ms=24 size=0
The issue is when i run K6, the data is not getting written into DB and hence cant see them in the grafana.
Hi @jeevananthank - docker-compose is not working on scenarios implementation. I am using shared iterations scenario.
This works without docker-compose, but when i use docker-compose it doesn’t work…it just run for 1 iteration can you help if any specific setup needs to be done for docker-compose?
