grafana v8.5.5 -
I try to display the job newest status in the table line. -
The data source is loki. I have some log lines from the syslog and I use the query{job="app"}|pattern "<_>HPCTRACE: <_>: <_>: <message>"|line_format "{{.message}}"
and choose the last value for the message by the group by in transform. -
What happened?
the message is not correct, because it is sort by the character rather than time stamp order. -
I want to display the last one message by timestamp order. -
No errors -
Transform data | Grafana documentation
A screenshot and some examples would probably help.
