Hi. I’m building a panel that is repeated over a template variable whose values can contain spaces. When I include this variable in the panel’s query, the selected value is plugged into the query without surrounding quotes causing inaccurate results…
I was able to observe this behaviour (of the way the query is built, if not the results) in the “Elasticsearch Templated” live demo dashboard and capture the query when 1) the panel was not repeated and 2) when it was repeated over $host:
Panel is not repeated - the parameter is quoted and surrounded in parentheses.: ““query”:”@hostname:(\“server\\ 20\”)""
“request”: {
“method”: “POST”,
“url”: “api/datasources/proxy/3/_msearch”,
“data”: “{“search_type”:“query_then_fetch”,“ignore_unavailable”:true,“index”:[“metrics-2017.10.18”]}\n{“size”:0,“query”:{“bool”:{“filter”:[{“range”:{”@timestamp":{“gte”:“1508362785750”,“lte”:“1508363085751”,“format”:“epoch_millis”}}},{“query_string”:{“analyze_wildcard”:true,“query”:"@hostname:(\“server\\ 20\”)"}}]}},“aggs”:{“3”:{“terms”:{“field”:"@hostname",“size”:5,“order”:{“1”:“asc”},“min_doc_count”:1},“aggs”:{“1”:{“max”:{“field”:"@value"}},“2”:{“date_histogram”:{“interval”:“500ms”,“field”:"@timestamp",“min_doc_count”:0,“extended_bounds”:{“min”:“1508362785750”,“max”:“1508363085751”},“format”:“epoch_millis”},“aggs”:{“1”:{“max”:{“field”:"@value"}}}}}}}}\n"
Panel is repeated for $host: ““query”:”@hostname:server\\ 20""
“request”: {
“method”: “POST”,
“data”: “{“search_type”:“query_then_fetch”,“ignore_unavailable”:true,“index”:[“metrics-2017.10.18”]}\n{“size”:0,“query”:{“bool”:{“filter”:[{“range”:{”@timestamp":{“gte”:“1508362553004”,“lte”:“1508362853004”,“format”:“epoch_millis”}}},{“query_string”:{“analyze_wildcard”:true,“query”:"@hostname:server\\ 20"}}]}},“aggs”:{“3”:{“terms”:{“field”:"@hostname",“size”:5,“order”:{“1”:“asc”},“min_doc_count”:1},“aggs”:{“1”:{“max”:{“field”:"@value"}},“2”:{“date_histogram”:{“interval”:“500ms”,“field”:"@timestamp",“min_doc_count”:0,“extended_bounds”:{“min”:“1508362553004”,“max”:“1508362853004”},“format”:“epoch_millis”},“aggs”:{“1”:{“max”:{“field”:"@value"}}}}}}}}\n"
Is this by design for some reason? How can I force the quotes?
Thanks.
Vamsi.
UPDATE
I believe the quotes and parentheses are added around a single selected value in the query only if the template’s selection options include “Multi-value”
