Table Panel Columns to Rows
Hi All,
Managed to queried this:
With this query:
SELECT patchsession,
count(*) as Baseline,
COUNT (*) filter(where exempted='SKIP_L2_APPROVAL') AS SKIP_L2_APPROVAL
from patchtracking P, cycle C
where C.cyclename=$cyclename and P.patch_id=C.id
group by patchsession
Is it possible to query it so that it display this:
                            UAT
Baseline                    78
Skipped with L2 Approval    14
Thanks,
HY
Hi. I am stuck in similar problem. You got any solution.
Any idea how to do this ?, We have a table which always ends up with one row , but with 50 columns
Can the columns become rows ?
we are using logs in Metric to pull all columns of the record
Same here. Need this functionality
I need this one as well, any updates ?
Maybe unnest can help you. I use it with Crate.io and I think is the same with Postgre.
same situation here, I solved this by using transformation -> reduce ->mode: series to rows, calculation: total
This Example Dashboard helped me a lot figuring out whats going on in case anyone else struggles with this kind of basic cluelessness.
Thanks, Series to rows saved me as well when i wanted to display data in Bar Chart
great!
