Table Formattnig
  • What Grafana version and what operating system are you using? - Grafana 8
  • What are you trying to achieve? - Tabular data with Service status
  • How are you trying to achieve it? - Data Source as MySQL
  • What happened? - Able to get the data in table but not sure how to add legend on the status like if Service is Active then green else red
  • What did you expect to happen? - If Service active then Legend for the status box should be Green else Red
